Old 04-18-2010, 05:36 PM
geno geno is offline
Default can,t get idle up
2005 ec 200 - idle screw is turned in all the way can,t get idle up any more air screw is adjusted. bike runs great could it need a one size smaller pilot jet ? just need to get a few more RPM at idle.
thanks geno
Old 04-18-2010, 08:49 PM
webmaster's Avatar
webmaster webmaster is online now
Administrator
What needle do you have in it now?
If you go one size leaner on the pilot - it will just worsen the situation you are in. Going with a leaner needle and a richer pilot will help.
Right now - you are "pulling over" - which is having the idle screw cranked in to supply more fuel/air via the nozzle/needle - this is because the pilot is lean, etc. But it's a circular problem - needle too rich/pilot too lean then crank up idle to try to balance air/fuel ratio....
The ultimate fix is to send your carb to RB-Designs - he fixes the carb internally to resolve the sensitivity issue that it has on the idle/pilot circuits, bores it out and installs a divider plate, etc.
gas gas won't idle? read this! ricardo cabeza Enduro Intake/Carburetion - 2 stroke 19 10-07-2013 01:33 PM
fasr idle woody1965 Enduro Engine - 2 stroke 1 02-26-2010 12:46 PM
EC 250 05 noo idle. settings?? Laban1234 Enduro Intake/Carburetion - 2 stroke 5 07-21-2009 11:13 AM
OK, how do I adjust the idle thelonius General Discussions & Announcements 2 04-25-2009 07:41 PM
Low Oil light at idle floored Enduro Engine 4 stroke (including EFI & Exhaust) 3 10-02-2008 09:49 AM
