Old 07-12-2010, 06:35 PM
wavemanz wavemanz is offline
Default 2001 EC 300 200lbs rider Basic settings for New England H/S and Enduros
Hello,
I'm hoping you can help me set my baseline. I'm six foot 200lbs B rider. I live in Tahoe but I'm moving to New England and will race a few NETRA events probably H/S Enduros and Turkey runs. I grew up riding in N/E the terrain is tight mostly 1-2-3 gear sections. I know how to work on the bike and how to make adjustments. What I need are good baseline settings for my Ohlins shock and my fork.
Basic settings for a B level New England H/S and Enduro rider.
FORK
1) I want to replace the fork oil and setup the forks. Whats the proper fork oil WT and how much per leg? Do I remove the forks and springs then drain fluid compress the forks fully add oil until.
3) Rebound, clicks out?
4) Compression, clicks out?
REAR OLIN SHOCK
1) Rider sag = how many mm ?
2) Spring pre-load ? Is this bike on the stand measure point to point then take the bike off the stand and remeasure? This will tell me if this are OK or if I need a stiffer Spring after setting SAG correct?
Chassis adjustments;
The upper fork tube position in the clamps. Should I set this 5mm up past the upper clamp?
I can fine tune later, but I need to get the baseline.
Do not go where the path may lead, go instead where there is no path and leave a trail.
Emerson
Reduce consumption - Reuse and only then recycle.
Take care
David
Old 07-12-2010, 07:01 PM
where are you going to be living in new england??
Old 07-13-2010, 08:09 AM
widebear's Avatar
widebear widebear is offline
Banned
Default spec baseline
try this for starters
Originally Posted by wavemanz View Post
Hello,
FORK
1) I want to replace the fork oil and setup the forks add .44 springs. Whats the proper fork oil 5 WT and how much per leg? 115 mm from the top Do I remove the forks and springs then drain fluid compress the forks fully add oil until yes,.
3) Rebound, clicks out? 8-10
4) Compression, clicks out?10-15
REAR OLIN SHOCK
1) Rider sag = how many mm ? 100 to 105 with 5.5 kg per mm
2) Spring pre-load ? Is this bike on the stand measure point to point then take the bike off the stand and remeasure? This will tell me if this are OK or if I need a stiffer Spring after setting SAG correct? min 20 mm free sag
3) Rebound, clicks out? 18
4) Compression, clicks out? 12-15
The upper fork tube position in the clamps. Should I set this 5mm up past the upper clamp? to taste
Emerson
Take care
David
Old 07-13-2010, 08:04 PM
Default Hi Skid
Hi Skid,
I'm not sure yet, depending on work. CT, NH, ME but I may have to live in Jersey? I'm sure the riding in NH is very nice. My brother J.C lives in Ct and said most of the trails we used to ride are closed?
Thanks
Dave
Gas Gas EC 300 09 Basic Suspension Settings snaissidis Enduro Suspension 0 03-16-2009 04:05 PM
2001 EC 300 Suspension set up 200 rider wavemanz Enduro Suspension 5 12-13-2008 10:08 PM
2001 Ec 300 Jetting 3500-7000' 200lbs rider wavemanz Enduro Intake/Carburetion - 2 stroke 8 11-28-2008 10:44 AM
Basic Settings for 2005 DE250 the eel Enduro Suspension 1 09-02-2006 12:37 PM
AMA pushing away from time keeping enduros gasgasman General Discussions & Announcements 14 08-03-2006 07:51 PM
