Old 09-11-2010, 12:57 PM
Caravan Monster's Avatar
Caravan Monster Caravan Monster is offline
Default Bushes for fixing plastics
Is there an affordable alternative for replacing the bushes which stop the plastics from being crushed when you tighten the M6 bolts that fix plastics such as the sidepanels? I would imagine another manufacturer has a cheaper (presumably pressed) item. The machined Gas Gas bushes are expensive (£5 UK ea.)
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 09-11-2010, 07:16 PM
GMP's Avatar
GMP GMP is offline
I go to a good local industrial hardware supplier for stuff like this, o-rings, metric hardware, etc. Not sure what you have available in the UK but you can likely find an alternative for a fraction of the cost of OEM.
What immediately comes to mind for your request is an M6 weldnut. Just drill the threads out and grind to length to match the plastic thickness. I did this on my Hyde combo skidplate.
Old 09-12-2010, 10:18 AM
Yes, I'll probably make up some spacers. I'll check some of the other dirt bike manufacturers first though. I'm sure one of them must produce a cheap bush.
'13 Husaberg TE 300
Old 09-12-2010, 11:07 AM
stainlesscycle's Avatar
i use a bonded fender washer. it's a sealing washer with 1 side rubber, 1 side steel. works well, gives larger contact patch too.. it works for the holes that top hat bushes have been torn out..
07 ec300
www.stainlesscycle.com
Old 09-12-2010, 12:39 PM
GMP's Avatar
GMP GMP is offline
Another trick for torn out plastic mounts is to use a rubber stopper of the closest size to the tapered recess in the plastic, cut to length. Drill a hole through it and use a fender washer on top. When its tightened it expands and captures the plastic, way stronger than an OEM shoulder washer, perfect for fixing shroud mounts.
Old 09-17-2010, 01:37 AM
vfrrocks's Avatar
vfrrocks vfrrocks is offline
I use this type grommet, it work fine and my local shop carries them. cheap too.
the last ones i purchased were about 50 cents each.
you don't have to live on the edge, just know where it is.
____________________
Ken
05 GasGas EC300
05 Honda CRF450X
98 Honda VFR800
89 Honda RC31
Tech Tip: Fixing the kickstand auto-retraction MattR Enduro Chassis & Body 41 04-10-2022 10:39 AM
gas gas plastics johns2394 Enduro Chassis & Body 1 12-09-2008 06:44 AM
Where to get plastics 98 EC - UK jazzy Enduro Chassis & Body 0 09-24-2008 04:43 AM
Marzocchi 45mm bushes iancp5 Enduro Suspension 0 02-25-2008 02:49 AM
Help with plastics brains Enduro Chassis & Body 3 07-12-2007 10:40 AM
