Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
More power
Hi i have a quad gasgas 450 injection model 2005.
How can ik get easily more power? Maybe some standard restriction? But it must be reliable. Thanks. I am from holland so my english is not very good but I do my best. |
Can nobody help me or give me some advice?
Have you changed the wires on the ECM to set it to use the "race" map?
jeff |
Can you change it to the race map with the wires?
I thought you need a pc with a programme to switch it to the race map. |
I am assuming that the quad has the same electronics as the enduro. There are two maps programmed in from the factory. It may come with it set to the "mild" setting. Make sure the yellow/blue wire is disconnected from blue/yellow wire on the ecu to select the race map.
jeff note : The yellow/blue wire is labeled Y/L on the schematic, whereas the blue/yellow wire is labeled L/Y on the schematic. Last edited by webmaster; 03-13-2007 at 11:03 PM. Reason: For Clarity... |
My FSE450 came with a throttle restriction. I don't know if that is the case with your quad. If it is, grind off the little thingy sticking out on the gas wire bracket. The red line in the pic shows how it used to look.
no power | bruno | Enduro Intake/Carburetion - 2 stroke | 4 | 05-18-2010 10:56 AM |
power now | Gassey fan | Enduro Intake/Carburetion - 2 stroke | 4 | 04-29-2010 12:08 PM |
200 power | nwrider | Enduro Engine - 2 stroke | 2 | 03-24-2010 09:26 AM |
More power in 250 EC | Henrik | Enduro Engine - 2 stroke | 5 | 09-24-2008 07:26 AM |
Power Now | gasIdaho | Enduro Intake/Carburetion - 2 stroke | 10 | 01-24-2007 10:25 AM |
