Old 02-28-2011, 11:49 AM
Vinny's Avatar
Vinny Vinny is offline
Default 450 Enduro wont start / no spark
Hi. Hope someone can help me on the right direction.
I have a GG450 enduro that just stopped running on the trail. It was running perfect for 3 hard days and then it just stalled. I tought it might overheated or flooded so waited for a while. When it didnt start then, I took of the tank and got to the spark plug wire. Pushed the starter w/ the wire off and checked w/ omhs meter.....nothing / no power.
Any ideas ?? Is there a computer or something that I should look into ??
Thanks. Vinny.
Austin, Tx
Old 02-28-2011, 11:53 AM
gasgasman's Avatar
I would check all the fuses first.
Old 02-28-2011, 12:41 PM
GMP's Avatar
GMP GMP is offline
Main relays have been know to be a problem, not a properly sealed component for the application. This same thing plagued Cannondales as well, with he exact same symptoms. Could be a cheap fix.
I'll move this thread to the 4-stroke forum.
Old 02-28-2011, 09:49 PM
gasmonkey's Avatar
gasmonkey gasmonkey is offline
Bronze Level Site Supporter
Check the wiring loom and connectors behind headlight.They're a dnf just waiting to happen.I've solderd mine solid and shrinkwrapped them to remove any doubt.Automotive conectors on a dirt bike is just plain crap.Also check engine kill switch etc.
Good luck.
Old 03-01-2011, 10:58 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
Check out the ignition switch as well. I seem to remember Nick (site sponsor here) had a problem with his when were out riding.
06 Gas Gas FSE 450 USA
Old 03-01-2011, 05:18 PM
Vinny's Avatar
Ignition is good // wires are hooked up // only found one fuse, it was ok.
Old 03-01-2011, 05:30 PM
Crankin04 Crankin04 is offline
Check the fuses in the electrical compartment. It's on the right side of the bike (looking from behind it) behind the plastic underneath the seat and over exhaust. I had this same problem and it was the red 10amp fuse that blew.
Good luck and let me know.
Crankin04
04' GG FSE 450
Live Easy, Ride Hard!
Old 03-05-2011, 12:43 AM
Vinny's Avatar
Crankin04
Its now at the dealer. fuses on R side by exhaust checked....they are ok.
Now what ? Frustrated
Old 03-11-2011, 05:50 AM
Vinny's Avatar
Default TJ cycle / austin, tx
Now my dealer is frustrated. They have checked all the wiring and obvious stuff.....no results.
They dont have a diagnosis computer; should they ?
It seems to me that if you are a dealer the equipment required to do your job should be available .
Does the GG 450 have a port to hook up a computer diagnosis ??
Old 03-11-2011, 09:27 AM
iancp5's Avatar
iancp5 iancp5 is offline
You said that the issue is no spark and the fuses are all ok?
You can only check backwards from the plug. Is power getting to the coil if it is then check ECU is being powered up and that it is getting inputs from sensors such as crank position if it is then it's the ECU and you need to find one to swap to check it.
2005 FSE450 wont start itsagas Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-16-2010 08:38 AM
02 EC 300 wont start GENO 300 Enduro Engine - 2 stroke 0 09-21-2009 10:02 PM
EC200 wont start Skele Enduro Engine - 2 stroke 25 09-06-2009 10:34 AM
wont start clerky clerk Enduro Engine - 2 stroke 8 11-01-2008 01:18 PM
2000 Xc 250 wont start In mesa arizona justinmanus Enduro Engine - 2 stroke 9 12-25-2006 04:46 AM
