Old 04-21-2007, 01:58 PM
Rappa's Avatar
Rappa Rappa is offline
Default '03 fse450 speedo ???
Does anyone have a clue on how to operate the speedo on the 03's. I went through the 04 manual which is availalbe on the web, but that has a different speedo. Hopefully someone can direct me to a site or can upload an 03 manual. Thanks in advance - Rob.
Old 04-21-2007, 02:07 PM
Brian VT Brian VT is offline
The '03 manual explains it pretty well, I thought.
Post some specific questions and I'll try to answer them if you don't want to mess with the manual.
Old 04-21-2007, 02:15 PM
Rappa's Avatar
That's the thing, I do not have an 03 manual. I'm the second owner and wasn't supplied with it. So I just need to figure out what the function of it is. Example: what does the on off feature mean, how to go from km to mph, how to properly operate the "start" and "mode" buttons, ext...
I would love it if you were able to scan what you have so I can see it or if you might know of another way.
Old 04-21-2007, 03:15 PM
I can't find the link to the '03 manual.
To change from kph to mph: Disconnect the battery then hold down either of the buttons while reconnecting the battery.
The top button is the reset button.
The bottom is the mode button.
The initial display is the clock. If you press the mode button it goes:
Speedo, Speed, Total Distance, Trip Distance.
To change the time:
-Press mode until time is shown.
-Press and hold mode and then adjust hour with top button.
-Press mode again and adjust minutes.
-Press mode again and time is set.
To zero trip distance:
From time display press mode 3 times and hold to zero trip.
Old 04-21-2007, 09:44 PM
Rappa's Avatar
Here is a pic of my speedo on my '03 GasGas FSE450 whice as you can see is completly different than the '04 model. So I appreciate your help and info Brian VT, however it does me no good. Hopefully someone see's this and has an answer for me. Thanks to all who respond.
Old 04-21-2007, 11:16 PM
The 'puta' that came with my '03 EC300 is not that one.
Sorry.
Old 04-22-2007, 07:44 AM
Rappa's Avatar
Sorry.
That's what I figured. Thanks anyway.
ec 250 speedo help gregtenerife Enduro Electrical & Wiring 3 06-17-2010 01:06 PM
02 EC250 speedo Viv Enduro Electrical & Wiring 9 06-21-2008 01:09 PM
EC 300 speedo ?? oldgoat Enduro Electrical & Wiring 7 08-11-2007 03:29 AM
