Old 09-28-2015, 03:24 PM
12Bravo's Avatar
12Bravo 12Bravo is offline
Default Won't Idle in Gear
I HAVE read a bunch of post on this forum and others about this. But can't seem to get a clear understanding of what might be the issue.
Would like a little help to eliminate what it might or might not be.
This is what I have happening. Idles good in N, pull clutch shift into first, idles for 5-10 seconds then bogs down and dies unless I blip the throttle.
I have watched several youtube videos on proper hydro clutch adjustments, I have done so. The bike is even hard to roll/push when in gear and clutch pulled in.
I checked the fluid, it is dark but not black and is half way full in the M/C. I'm going to get fresh DOT 4 and bleed it to see if that is the issue, I don't think it is, but will do it anyways as an excuse for maintenance, that looks like hasn't been done on this bike. The more I tear into it, the more little issues I am seeing with it. Oh well, I'll just call this the Stupid Tax for learning a new hobby.
Sorry, I'm new to these, learning as I go. Please be patient till I figure this stuff out.
Old 09-28-2015, 04:12 PM
What year bike? You should use dot oils in most clutches. I use atf in mine. If it's an old bike it's likely the clutch fins have notched, either replace or file. I replaced my basket with a Barnett, it is beautiful!!
2016 RM-Z450
Old 09-28-2015, 04:58 PM
12Bravo's Avatar
It's a 99 EC200. I just rode it for about 15 minutes, not as snappy as I was think it was going to be, but I'm over weight. Which might be in my benefit for learning, kind of tame the beast till I get comfortable.
I have DOT 3 for the brakes, brand new M/C and lever. Bleed just fine.
The engine idled after about 15 minutes of riding. So maybe I just didn't let it worm up enough earlier today. I put Walmart ATF in the gear case, which I have read some positive reviews about, on here and other forums.
One thing I noticed, I need to build my clutch fingers up, only using two fingers, now my arm is tired after only 15 minutes of riding.....wow, can we say out of shape!
Once this clutch drops, I'm going to get new plates and inspect the basket. Hoping it is fine with just a touch up and a file. But if not, then Barnett it is, seen some good reviews with them also.
Old 09-28-2015, 06:14 PM
12Bravo's Avatar
When you say ATF in your, what brand?
It calls for DOT 4, in a pinch could I use DOT 3 till I get to town to get some DOT 4? I live 20 miles from town.
Old 09-28-2015, 06:43 PM
Double check the MC for the clutch before you hook in. Some take mineral oil, others brake fluid. Not interchangeable.
Both of my Gassers have a bit of clutch drag (and have from new). Most noticeable with fresh oil and a cold engine. It's not to the extent that it makes the bike hard to start in gear, or that the bike will try and lurch forward with throttle and the clutch pulled, but is enough friction to drop the revs down a tad.
I don't expect my bike to idle in gear excessively though either. If it's in gear I intend on keeping the bike moving. If I'm stopped I usually kill the engine. If I stall down a hill a quick bump brings it back to life. These engines are easy enough to live with once you get them set up. I can bump the idle up to counter act the stalling out, but I don't like the way the engine feels and responds with a higher idle, particularly while trailing revs with a closed throttle.
Old 09-29-2015, 02:19 AM
(F5)'s Avatar
(F5) (F5) is offline
Check the inner basket for wear too. But why would you idle it in gear for any time?
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 09-29-2015, 06:06 AM
12Bravo's Avatar
Stopping to go down a hill, learning to ride.
Plus it is ridiculous to get into N after the bike is running. With its off, it pops right into N but when it is running not so much.
Old 09-29-2015, 06:47 AM
eff's Avatar
eff eff is offline
I started running Amsoil 0W-40 and that made a big difference in clutch performance. I highly recommend it.
2004 GasGas DE250
Old 09-29-2015, 07:17 AM
I use any atf dexron oil for my clutch, 6 is the best, 2 is the worst, you can also use it as a gear oil.
I hold mine in neutral because my bike is road registered and it makes every trip to the shops that bit more insane ! There should be no drag AT ALL. Any drag is indicative of something amiss.
2016 RM-Z450
Old 09-29-2015, 08:08 AM
Brian VT Brian VT is offline
Engine oil can make a bit of difference too.
I noticed less clutch drag when I switched (many years ago) to
Rotella 5W-40 synthetic as recommended by the good folks on this site.
I suspect you have other issues, though. I only use 1 finger on my '03 clutch lever and it never gets tired.
Wanted!! Ec200 seat, radiators, switch gear, gear lever Kendog "Wanted to Buy" & "Want To Trade" 2 10-12-2014 03:12 PM
02 400 will not idle jason r Enduro Engine 4 stroke (including EFI & Exhaust) 7 11-18-2013 04:14 PM
Bad idle Madhead Enduro Intake/Carburetion - 2 stroke 1 08-11-2011 06:20 AM
Does not idle or rev Binni Enduro Intake/Carburetion - 2 stroke 8 02-14-2011 03:29 PM
can,t get idle up geno Enduro Intake/Carburetion - 2 stroke 1 04-18-2010 08:49 PM
