Old 04-29-2021, 06:41 PM
GGracing GGracing is offline
Default '17 ec300 stator specs
I am trying to locate specs for the stator- I found a service manual for an 18 which I believe still has the Kokusan 2K-3 stator but none of the color coding matches plus I have a RED/BLUE lead that has been taped off. Has anyone come across this odd colored harness? I'll try and put attachments of photos.
Thanx
Old 04-30-2021, 12:20 PM
Neil E. Neil E. is offline
I'm not sure what you are asking. Pic 1 shows a pink/brown/white connector. Pic 2 shows two connectors red/blue and white/brown/yellow. Are all these disconnected on your bike? Or did you unplug them to take photos?
I expect all GG bikes use the 2K3 stator, but with different wiring looms depending on the year and model. Some bikes use AC powered CDIs and some use DC powered CDIs.
The 2K3 probably has a 75W output although I haven't seen published specs.
2011 EC250E
Old 04-30-2021, 08:46 PM
If pic 2 comes from the stator (wires exit the engine case at 2:00 o'clock) the red/blue wires are probably the larger "single winding" on the stator. This is the impulse coil that powers an AC CDI. You likely have a DC CDI so these wires are not used.
Is pic 1 is the female connector that pic 2 male connector plugs into? If so those wires are for the lighting coils.
2011 EC250E
2018 Ec300 Jetting Specs Mud-Ectomy Enduro Intake/Carburetion - 2 stroke 53 11-17-2021 01:48 PM
Confirm Torque Specs for Forks/Linkage for 2018+ EC300? Booki Enduro Suspension 13 06-07-2019 08:34 PM
'06 EC300 stock handlebar specs? brider Enduro Chassis & Body 0 09-16-2013 03:08 PM
2010 EC300 Factory Jetting Specs - WTF? JP4 Enduro Intake/Carburetion - 2 stroke 197 07-04-2011 11:03 AM
2010 Sachs fork factory compression stack specs(ec300) bergerhag Enduro Suspension 9 07-01-2010 11:18 PM
