Old 07-20-2009, 05:31 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Default knocking noise
I think I can hear a knocking noise from my 300 and am thinking maybe it's the piston/little end.
Is there anyway to check, if it's gone would I feel play when trying to move the piston up and down if I remove the barrel?
If it's gone will I need a new conrod as well?
I will do a compression test shortly - should that show it up?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 07-20-2009, 07:47 AM
darren's Avatar
darren darren is offline
From my experience -
Rattle/chattering = Small end,
Knocking = Big end,
Rumbling = Main bearings.
If you remove your barrel hold the con rod still and try to move the piston up and down if there is play then you have found your problem.
Also hold your con rod and try to move that up and down to check the big end.
If it is the little end providing the con rod is not damaged or mis shapen you could get away with just a bearing and gudgeon pin.
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
Old 07-20-2009, 07:53 AM
darren's Avatar
Also when you remove your cyl head, check the head and piston crown to see if the piston has been striking the head.
It would be worthwhile before stripping to check the stroke in mm to see if it differs from the book. If it is shorter then something has failed. (little or big end)
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
Old 07-24-2009, 03:05 AM
Measured compression today at 130 so it's lost some from the 150 originally.
Will continue to dismantle, hopefully just a new piston, rings, wrist pin and little end bearing should do it...
'05 Gas Gas 300
'99 KTM 200
Old 08-01-2009, 08:08 AM
Diddel Diddel is offline
Mounts to bloke.
Old 08-01-2009, 04:26 PM
darren's Avatar
Originally Posted by Diddel View Post
Mounts to bloke.
What???
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
Old 08-06-2009, 12:22 PM
DaveJ DaveJ is offline
What if there's no movement up or down, yet you can rock the connecting rod side to side a few mm's?
'06 GasGas EC300
Old 08-06-2009, 03:30 PM
rpduc rpduc is offline
There are specs in the service manual for side clearance on the big end.
When I did my top end this winter my big end was "just" in tolerance by this measurement so I left it and no probs yet...
The only service manual available that I know of is the '06 one HERE
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
'07 Duc S2r 1000 still rubber side down...
May be so... May be not so...
My Website
Engine noise roostafish General Discussions & Announcements 11 11-24-2009 12:01 PM
Top end noise ? Link Enduro Engine - 2 stroke 7 01-17-2008 03:33 PM
clutch noise? LAWMAN Enduro Engine - 2 stroke 9 01-16-2008 08:15 AM
Bad Noise roostafish General Discussions & Announcements 17 01-10-2008 08:30 AM
Exhaust noise captainslow Enduro Engine 4 stroke (including EFI & Exhaust) 1 12-10-2007 07:26 PM
